Date/Time: Mon, 17 Mar 2025 03:44:42 +0000
Market Data By Symbol & Correlation
View Count: 653
[2022-08-25 12:50:25]
User998085 - Posts: 9
I would like to see a data grid that shows various symbols and the daily volume and other stats such as correlation between markets. I have seen this before in a simple grid / table form with multiple columns that can be changed to suit the user but I don't know what it is called so I have been unable to find it when searching in the Help/Support system. Also, if correlation is not one of the options on this grid I would like to know how to calculate correlation between markets and have it display as simple % (not a chart per se). For example NQ correlation to ES for the day is 92%, something like that. Appreciate your help.
[2022-08-25 13:47:57]
Sierra_Chart Engineering - Posts: 18801
You can use the Quote Board to list symbols and the current market values:
Getting Quotes
You can use the Study Summary to have a tabular view of study values from multiple charts:
Study Summary Window
And then you can add to those charts, those studies to perform the calculations that you need.
Have a look at these studies:
Study/Price Overlay Study
Correlation Coefficient
Date Time Of Last Edit: 2022-08-25 13:53:47
