Date/Time: Sun, 16 Mar 2025 23:55:15 +0000
How to I open Depth of market for bitcoin with thee same settings as these?
View Count: 420
[2022-08-25 11:28:03] |
BubuzinTrader - Posts: 11 |
Hello, I am doing a course from g7fx and he gives us the template attached to use depth of market for US500, oil, etc. How to I open Depth of Market with the same settings as in the template but for bitcoin and ethereum?
[2022-08-26 10:46:08] |
Sierra_Chart Engineering - Posts: 18800 |
Just open a chart for the particular symbol and then open the Market Depth window: File Menu: Open Market Depth Window (File) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
