Date/Time: Thu, 19 Sep 2024 22:02:22 +0000
CQG QTrader
View Count: 2240
[2014-05-13 15:12:13] |
User51517 - Posts: 58 |
Hello, I'm doing a demo on CQG QTrader. I was wondering if my user name/password on the CQG QTrader demo will be able to connect in Sierra Chart as well. Thanks |
[2014-05-13 16:47:30] |
Give it a try. Here are the set up instructions: http://www.sierrachart.com/index.php?l=doc/CQGTrading.php#SetupInstructions Although we suspect that this will not work. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
