Date/Time: Sun, 16 Mar 2025 23:52:52 +0000
hidden drawing
View Count: 471
[2022-08-25 06:09:47]
nicktrader - Posts: 744
The picture shows the order in which the drawings were made. The rectangle hides the first line.
Is there a way to adjust it?
imageDrawings.png / V - Attached On 2022-08-25 06:09:36 UTC - Size: 13.53 KB - 115 views
[2022-08-25 10:49:34]
Sierra_Chart Engineering - Posts: 18799
Yes. Refer to:
Chart Settings: Draw Highlight Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Chart Drawings menu)
