Date/Time: Mon, 17 Mar 2025 18:22:48 +0000
Options Data Teton / Denali - Nymex
View Count: 459
[2022-08-25 04:51:24] |
eaglefutures - Posts: 48 |
I keep getting error messages for all the options symbols intraday or historical LOV22 P9550.FUT_OPT.CME I cant seem to open it on a chart or on a DOM. Is there some setting which I need to apply . Are options trading supported on Teton? |
[2022-08-28 17:38:53] |
Hi Support any feedback on what I need to do?
[2022-08-29 07:06:50] |
We need to do some work on this to resolve this issue. Options trading on Teton order routing is not supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-13 21:11:58] |
Sierra_Chart Engineering - Posts: 18809 |
This will be solved in the next release.
