Date/Time: Mon, 14 Sep 2026 09:31:26 +0000
how to open DOM and chart by using quoteboard
View Count: 1070
| [2022-08-25 01:53:05] |
| BubuzinTrader - Posts: 11 |
Hello, I am making a course from G7FX and he provides this file to use to open depth of market and a chart at Sierra. I added BTC from Binance to the quote board and I want to open DOM and the chart in the exact same was as oil, sp500 and others are oppened automatically. how can I do it? Sorry, I am a very beginner in using Sierra |
| [2022-08-26 10:47:38] |
| Sierra_Chart Engineering - Posts: 24859 |
We recommend using this particular duplicate chart functionality: File Menu: Opening a New Chart that uses the Same Settings as the Active Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
