Date/Time: Thu, 19 Sep 2024 21:40:27 +0000
horizontal lines shift
View Count: 925
[2014-05-13 14:39:52] |
User28682 - Posts: 233 |
Hi, I am drawing horizontal lines from tops/bottoms of cumulative delta bars as reference points. The next day when I log into SC the lines move?? and I have to redo them all, any suggestions? Thanks Tom |
[2014-05-13 16:34:59] |
Help with this is documented here: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#CDBDrawingTools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
