Date/Time: Tue, 22 Apr 2025 02:21:34 +0000
[Locked] - S&P Sector Indexes - Missing some Symbols
View Count: 1714
[2022-08-25 00:03:54] |
User337568 - Posts: 61 |
Consumer Staples - $IXE Utilities - $IXU Communications - $SRTS I didn't find XLC Financials - $IXM - Didn't find XLF Materials - $IXB Industrials $IXI Energy - $IXE Real Estate - $IXRE Health Care - $IXV Information Technology - Didn't find XLK Consumer Discretionary - $IXY |
[2022-09-14 16:24:36] |
Hi: I am interested in $XLK and $XLC. I looked through the Find Symbols - Indexes S&P (Realtime), and I did not find these listings. |
[2022-09-16 17:05:06] |
Sierra_Chart Engineering - Posts: 19290 |
If these are actual S&P Index symbols we will get them added to the list.
[2022-09-16 18:43:57] |
Hi: Source: https://www.spglobal.com/spdji/en/indices/equity/sp-500/#data Current Sector breakdown of S&P500: SECTOR INDEX WEIGHT XLK - Information Technology 27.3% XLV - Health Care 14.1% XLY - Consumer Discretionary 11.4% XLF - Financials 10.9% XLC - Communication Services 8.4% XLI - Industrials 7.9% XLP - Consumer Staples 6.8% XLE - Energy 4.7% XLU - Utilities 3.1% XLR - Real Estate 2.9% XLB - Materials 2.5% ETF - State Street: https://www.ssga.com/us/en/intermediary/etfs/fund-finder?tab=overview&g=assetclass%3Aequity!noLabel*Sectors---Industries%7Cmarket-cap*Large-Cap |
[2022-09-16 20:26:28] |
A dumb question: Will I be able to get all the symbols on Service Pack 12?
[2022-09-20 21:19:56] |
The package you are on does not make any difference to what symbols you can get access to, apart from the basic need to be on an integrated package in order to use the Denali Exchange Data Feed. The symbols that are available are determined by the exchange selected. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-22 09:58:05] |
We looked into this. All of these indices are already listed in File >> Find Symbol >> Indexes S&P. The symbols are different than what you gave. So you need to search by description. If any are missing, let us know but they should all be there. You can open Historical Daily charts and get data. However, if you need real-time data refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Cash Indexes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-22 09:58:30
[2023-02-19 08:24:00] |
User204287 - Posts: 1 |
It seems like ($IXC) S&P Communication Services Select is not there.
[2023-02-21 15:38:24] |
This is now added. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-22 01:07:53] |
58LesPaul - Posts: 429 |
I try to Find Symbol and select $IXC and get Invalid Symbol. I went through the link above to update Symbol settings.
[2023-02-24 11:12:30] |
Why does $IXC show invalid symbol when trying to create a chart? Thanks |
[2023-02-24 11:36:02] |
Therefore the symbol does not exist. Nothing we can do about that. So the symbol never existed to begin with. We will remove it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
