Date/Time: Sun, 16 Mar 2025 22:38:28 +0000
Common scale for independent lines
View Count: 458
[2022-08-24 17:05:39]
User953894 - Posts: 59
I use overlays on charts quite a lot, which involves selecting "independent" scaling for lines that do not use the same scale. How can I see a common scale for 2 (or more) lines with independent scales? I'm trying to use an alert to highlight when a crossover of the independent lines. Can I do this with the standard package or is this a customization that requires programming?
Thanks!
[2022-08-26 10:32:24]
Sierra_Chart Engineering - Posts: 18799
To do this, you need to use a separate Chart Region for those Overlay studies and then the Scale Range for those studies need to be set to Automatic.
Refer to:
Chart Studies: Settings and Inputs Tab >> Chart Region
Chart Scale and Scale Adjusting
Date Time Of Last Edit: 2022-08-26 10:33:27
