Date/Time: Mon, 17 Mar 2025 05:15:37 +0000
Custom DLL Study distribution by defined list of users
View Count: 631
[2022-08-24 11:32:17] |
tomna1993 - Posts: 24 |
Hello, I'd like to distribute some of my custom studies to a user group. I read in the documentation that there is a control panel for that but I can't find it. I assume that it will be available for me after I send you the user name of the person I want to send the study and include the DLL. If I want to distribute the same study for more persons, should I write every time a new ticket and include the study or I will be able to manage that in a control panel? |
[2022-08-25 13:54:22] |
Sierra_Chart Engineering - Posts: 18801 |
Yes here is the relevant documentation for what you need: Advanced Custom Study Interface and Language (ACSIL): Redistributing and Allowing Use Only by a Defined List of Users Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-01 17:28:47] |
Yesterday afternoon I provided the SCDLLName through account support ticket but still no response from Sierra. Can you tell me how long it takes to give me access to the control panel?
[2022-09-01 18:23:28] |
John - SC Support - Posts: 38678 |
Your ticket has been responded to.
