Date/Time: Thu, 19 Sep 2024 21:59:25 +0000
USDCHF charts are frozen
View Count: 1064
[2014-05-13 14:07:57] |
User76463 - Posts: 3 |
Hi the symbol USDCHF is not updating the charts are frozen. All of my other charts and symbols are working just fine. What is the issue? I am using (SC) Forex data FXCM.
[2014-05-13 17:00:52] |
We are testing this now we do not see a problem with this symbol. Reconnect to the data feed with File >> Disconnect and File >> Connect to Data Feed. If there is still a problem, refer to help topic 3: Http://www.sierrachart.com/index.php?l=doc/helpdetails3.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
