Date/Time: Sun, 16 Mar 2025 19:01:29 +0000
Volume At Price Threshold Alert V2 -Two comparison methods simultaneously?
View Count: 430
[2022-08-24 02:54:13] |
User173366 - Posts: 11 |
Hello Support Team, I want to have 2 comparison methods simultaneously in the "Volume At Price Threshold Alert V2" study. Specifically, Ask Volume Bid Volume Diagonal Ratio > 1000 AND Ask Volume Bid Volume Diagonal Difference > 100. I couldn't find a way to have both at the same time. Is there a way to accomplish this? Thank you |
[2022-08-24 11:23:35] |
Sierra_Chart Engineering - Posts: 18799 |
Use two instances of this study. Refer to: Chart Studies: Adding/Modifying Chart Studies You can also modify the study to meet your requirements: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
