Date/Time: Sun, 16 Mar 2025 21:28:40 +0000
Get Last Entry Trade DateTime in ASCIL
View Count: 377
[2022-08-24 00:21:58] |
User907609 - Posts: 17 |
This feature allows you to get the time of your entry in the spreadsheet trading study, are you able to call this in ASCIL as well? And if not is there a way to do this? |
[2022-08-24 11:15:43] |
Sierra_Chart Engineering - Posts: 18799 |
Yes this would be available in the Trade Statistics: ACSIL Interface Members - Functions: sc.GetTradeStatisticsForSymbolV2() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
