Date/Time: Wed, 19 Mar 2025 04:31:04 +0000
Can't change candlestick colors/ Vertical-Line at session start
View Count: 564
[2022-08-23 19:24:50]
User278435 - Posts: 12
1) after I changed my Data Feed from CQG to Denali, I can't change my candlestick colors?
( want up Candlestick in white and down candlestick in black)
I did: Chart - graphic/settings - unchecked Use Global Graphics settings -
Bar High-Low Down Black and Bar High-Low Up White, it didn't work)
2) Is it possible to draw a vertical-Line at session start, like in the old chart settings menu?
If so How?
Thank you!
Kevin.
[2022-10-15 08:30:34]
still can't change the collors of the candlesticks, if I change to OHLC bars the color does change.
Chart - graphics settings Chart- uncheck: Use Global Graphics Settings instead...-
- Bar High-Low Down- Black- Bar High-LowUp - White- Apply- OK.
Does not change the color; It does change the color of OHLC Bars and the Background of the Chart.
What can I do about it?
Thank you!
[2022-10-17 13:42:56]
John - SC Support - Posts: 38782
You need to change the Candlestick color settings. Refer to the information starting here:
Graphics Settings: Candlestick Up Outline
