Date/Time: Sun, 16 Mar 2025 23:52:52 +0000
Wrong pl displayed and calculated
View Count: 477
[2022-08-23 18:22:20]
pvt2020 - Posts: 5
Hi support team, mostly i use nq and es futures
just noticed that the calculation of the pl is wrong on the nq, the nq value point shoud be 20 usd and tick value is 5 usd, tick size is 0.25
please see the attached picture and you will notice that the calcul seems apparently wrong, i also attached the calculation for es which is right.
Thanks in advance for your advice
Best regards
zakari
imageesok.png / V - Attached On 2022-08-23 18:21:09 UTC - Size: 30.36 KB - 101 views
imagenqwrongpl.png / V - Attached On 2022-08-23 18:21:29 UTC - Size: 15.04 KB - 107 views
imagenq wrong pl2.png / V - Attached On 2022-08-23 18:21:33 UTC - Size: 14.95 KB - 98 views
[2022-08-23 18:22:48]
pvt2020 - Posts: 5
another file
imagenq wrong pl.png / V - Attached On 2022-08-23 18:22:39 UTC - Size: 109.6 KB - 103 views
[2022-08-24 11:12:09]
Sierra_Chart Engineering - Posts: 18799
Definitely disable Auto Set from Data Feed in the Chart Settings:
Chart Settings: Auto Set from Data Feed (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
Rithmic may be providing inaccurate information.
Refer to:
Profit/Loss Calculations and Symbol Settings
Date Time Of Last Edit: 2022-08-24 11:15:23
[2022-08-24 14:04:18]
pvt2020 - Posts: 5
Hi support team, thanks for your fast response, all resolved while following your advice.
Best Regards
