Date/Time: Mon, 17 Mar 2025 12:10:19 +0000
Study collection/template
View Count: 1331
[2022-08-23 15:40:48] |
User728750 - Posts: 24 |
Hi, is it possible that you could send me some study collection or templates with footprint? I dont know if you have any saved or do you know if some people shared some here. I would really apreciate it because its hard for me to create my own.
[2022-08-23 16:45:02] |
Sierra_Chart Engineering - Posts: 18805 |
First we see that your Sierra Chart account is expired. We have temporarily activated it. Regarding Numbers Bars, go through the instructions here: Numbers Bars: Step-By-Step Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-23 20:11:09] |
Thank you, but could you activate it in 2 weeks because im not home and i will be home in 2 weeks because of work.
[2022-08-23 21:58:39] |
Contact us again at that time.
[2022-09-07 15:11:13] |
Hi, im contacting you because of the free trial that. Could you activate it now? Thank you.
[2022-09-08 00:20:56] |
John - SC Support - Posts: 38678 |
You have had multiple free trials already, therefore we can not give you any further free time. To continue to use Sierra Chart, you will need to add funds to your account and activate a service package. Follow the instructions at the following link for this: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-08 13:14:29] |
But look what you told me about 2-3 weeks ago, you gave me free trial but i responded that im working away from home so i wont be able to use the free trial, so you said that i can contact you any time. So i contacted you again, and i wont get the free trial?
[2022-09-08 16:24:19] |
Sorry, yes we see that now. We will activate the trial this last time.
[2022-09-08 16:28:06] |
ok, thank you so much :)
