Date/Time: Sun, 16 Mar 2025 23:57:37 +0000
How do I change the P/L on the DOM
View Count: 1108
[2022-08-23 15:14:37]
meltradeer - Posts: 3
How do I change the P/L on the DOM from points to currency?
[2022-08-24 11:28:12]
Sierra_Chart Engineering - Posts: 18801
Refer to:
Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu)
[2022-08-24 19:43:06]
Rui S - Posts: 198
meltradeer,
I believe what are looking for is this:
At the top of the DOM, left-click several times where you have "P&L" until you get what you need.
As you will see, there are several options you can choose.
Hope this helps.
Date Time Of Last Edit: 2022-08-24 19:43:26
