Date/Time: Thu, 19 Sep 2024 21:50:59 +0000
overlay bar indicator - drawing visible
View Count: 979
[2014-05-13 14:05:07] |
User30743 - Posts: 364 |
helo, is it possible to make drawings (for ex. lines) visible on a chart that is set as an overlay bar indicator under a main chart? see the pictures for explation |
[2014-05-13 17:19:50] |
No. This will not work properly.
