Date/Time: Sun, 16 Mar 2025 16:21:49 +0000
Soybean Crush Spread
View Count: 555
[2022-08-23 13:45:07] |
User841161 - Posts: 260 |
I am having difficulties finding the symbol for the exchange traded Soybean Crush Spread. Looked under Soybeans and get spreads, and Soybean Meal and get spreads, but dont seem to see it. How would I get symbol to chart. Should be Soybean-Soybean Meal-Soybean Oil..
[2022-08-23 16:37:38] |
Sierra_Chart Engineering - Posts: 18797 |
Is this what you are referring to: https://www.cmegroup.com/markets/agriculture/oilseeds/soybean-crush.contractSpecs.html If so, we need to set up a symbol for this. It is: CME Globex: SOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
