Date/Time: Sun, 16 Mar 2025 12:25:41 +0000
"Use As Trade Only Symbol" option, does nothing?
View Count: 415
[2022-08-23 12:35:32]
j4ytr4der_ - Posts: 946
Hi SCE, I'm not sure if there is a bug here or not but at a minimum, it's a feature that seems to do nothing.
I can put a Trade Only Symbol in on a chart (or multiple charts with linking), and it will be used when trading regardless of whether or not "Use As Trade Only Symbol" is enabled anywhere. What is the purpose of this "Use" option? Why does it not apparently need to be enabled? The documentation certainly suggests that it should need to be enabled, for it to take effect...
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html&CAID=default#UseAsTradeOnlySymbol
Date Time Of Last Edit: 2022-08-23 19:46:12
