Date/Time: Sun, 16 Mar 2025 17:42:07 +0000
Numbers Bars Value Format
View Count: 455
[2022-08-23 10:32:31]
Mustang77 - Posts: 122
Hi
The study "Numbers Bars" shows large values, for example 45000.
in settings and inputs, if i set the Value Format to "LArge Integer With Suffix", it does not make the value 45000 as 45K.
is there a solution to this?
Thank you
[2022-08-23 10:38:33]
here are a couple of photos.
imageScreenshot 2022-08-23 123759.jpg / V - Attached On 2022-08-23 10:38:24 UTC - Size: 271.47 KB - 124 views
imageScreenshot 2022-08-23 123658.jpg / V - Attached On 2022-08-23 10:38:28 UTC - Size: 318.27 KB - 113 views
[2022-08-24 11:49:37]
Sierra_Chart Engineering - Posts: 18797
We still need time to review this.
[2022-08-30 15:33:58]
In the list of Inputs for the Numbers Bars study there is one named "Use Large Number Volume Formatting". Set that to Yes.
