Date/Time: Sun, 16 Mar 2025 16:21:49 +0000
Permanent enabling of keyboard trading globally?
View Count: 398
[2022-08-23 09:55:31] |
Colby Stoker - Posts: 31 |
Hi, I have searched, but unable to find if there is a capacity to turn on functionality of keyboard trading globally and permanently? Each time I close my chartbook it requires each keyboard trading on each DOM to be reenabled? I have tried to set up a shortcut key to simply allow keystrokes to enable the keyboard trading but doesn't seem to work. Let me know, (what the best way to do this is. Perhaps linking the trade window setting in DOM? My only concern there is if order size is set to be the same then that would be an issue) point me to a page, thanks. C Date Time Of Last Edit: 2022-08-23 10:04:09
[2022-08-23 10:13:08] |
Sierra_Chart Engineering - Posts: 18797 |
No that definitely does not make sense: Each time I close my chartbook it requires each keyboard trading on each DOM to be reenabled?
Make sure the Chartbook is saved: Chartbooks (Workspaces): To Save a Chartbook We verified there is no problem with this at all with the saving of that setting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-23 12:13:12] |
Yes, user error as usual. Thanks.
