Date/Time: Sun, 16 Mar 2025 23:47:51 +0000
pWhi and pWlo on RTH charts
View Count: 600
[2022-08-23 08:43:52]
User707307 - Posts: 84
I am currently using a Study/Price overlay to track the pWhi and pWlo on a weekly chart to the rest of the charts. The issue I found is I want the pWhi and pWlo to be RTH not ETH.
And When I change the chart where I get the pWhi and pWlo to Weekly it immediately updates to ETH. So the issue is - How can I change a weekly chart to RTH?
Thank you
[2022-08-23 09:38:13]
Sierra_Chart Engineering - Posts: 18799
This can be controlled through the Session Times:
Chart Session Times
Also refer to:
Chart Session Times: Session Times Automatically Changing Unexpectedly
You will want to use this study to do the calculations:
Previous/Period OHLC-Variable Period
[2022-08-23 10:02:10]
Oh yes that's helpful but the issue is when I cahnge to weekly. My charts change to a Historical, and I can't update then the session times.
[2022-08-23 11:15:56]
Refer to the information here for this:
Chart Session Times: Always Allowing Session Times to be Set
[2022-08-26 07:12:07]
OriolCasas - Posts: 189
That's helpful but the same issue still happens.
Even if I change the session time setting to intraday chart only, when I change the chart to weekly it goes back to historical.
I use that chart to extract the pWhi and pWlo, and I want this stats to be on RTH, otherwise I get the wrong info.
Thank you
[2022-08-26 11:05:18]
We are unable to reproduce the problem. How are you changing the chart to weekly?
[2022-08-26 11:12:20]
Let’s say I open an intraday chart. I go to session times and I tell the program to use intraday chart only and session times to RTH.
Then I go to a weekly chart, the program changes to all session time itself (ETH)
I hope I was able to explain myself good enough
[2022-08-29 07:08:46]
Exactly how are you doing this:
