Date/Time: Fri, 02 Oct 2026 14:15:26 +0000
IQ Feed Historical
View Count: 1390
| [2014-05-13 13:58:57] |
| User36082 - Posts: 4 |
Using IQ Feed data with daily historical charts with real time updating of historical charts. Want the session start and end times to match the symbol I am looking at. Do the global symbol settings affect the historical charts? The session end times are not correct intraday so the current bar continues beyond the close time. At some time during the evening after I close the charts the bars change because when I restart Sierra they are correct. Why do they correct on their own later? Is there a way to fix this. Do I need to set up all the charts as intraday charts and edit global intraday session times for each symbol to match? |
| [2014-05-13 16:22:38] |
Refer to help topic 12 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails12.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
