Date/Time: Sun, 16 Mar 2025 23:55:18 +0000
Trade DOM and Working Order Lines
View Count: 532
[2022-08-23 00:08:47]
Steve Leon - Posts: 312
Are you able to move the position of the working order and position lines into any other column other than the price ladder and not in the same area as the volume by price study when using that ?
Read the support manual and looked at chart settings > trading options as well as global settings but could not see a way to do this
Thank you
[2022-08-23 16:25:27]
Sierra_Chart Engineering - Posts: 18800
The only option would be:
Chart Settings: Align Trade Drawings Text to Right (Chart >> Chart Settings >> Trading menu)
and:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TradeDrawingsLeftAlignPercent
[2022-08-25 14:02:56]
Are you able to move the volume profile to a different column ? do you know of a custom study that might do this if it is not available ?
Thank you
