Date/Time: Sun, 16 Mar 2025 15:02:52 +0000
Imbalance target
View Count: 441
[2022-08-22 22:37:13] |
User707307 - Posts: 84 |
Hello, I am trying to add to the volume profile study, the projected imbalance target. A simple tool that tracks the imbalance of the profile (THE TARGET THAT WOULD BALANCE IT) How can I do this? Thank you |
[2022-08-23 16:40:01] |
Sierra_Chart Engineering - Posts: 18797 |
This is not very clear to us but have a look at the Volume by Price study: Volume By Price Study You can base volume bars on a diagonal calculation of bid and ask volume. Refer to: Volume By Price Study: Volume Bar Calculation Method Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
