Date/Time: Sun, 16 Mar 2025 16:21:51 +0000
20D avg range RTH/ETH
View Count: 450
[2022-08-22 22:25:57] |
User707307 - Posts: 84 |
Hello, I am trying to find a study to calculate the avg range of the last 20 sessions, one for the ETH and another for the RTH. A study that calculates the avg range of the last 20 sessions. As simple as that. How can I create such thing or is it already available on Sierra? Thank you |
[2022-08-23 11:11:04] |
Sierra_Chart Engineering - Posts: 18797 |
Have a look at this study: Average Daily Range And you can control the Session Times as needed: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
