Date/Time: Sun, 16 Mar 2025 12:28:17 +0000
Changing Futures Contracts for Simulation
View Count: 426
[2022-08-22 19:00:07] |
LegoMyGeggo - Posts: 3 |
Been scouring to try and figure this out with no luck, but as I'm doing my replays how do I change my contract so I can sim trade? For example I'm looking at ES in 2019/11/12. So I'd need to look at ESX19-CME, but I am currently on ESU22-CME. However, whenever I change my symbol to ESX19 it redownloads everything. How can I just change it so I can sim trade off the replay without having to redownload all the data? Thanks in advance!
[2022-08-22 19:56:53] |
Sierra_Chart Engineering - Posts: 18797 |
You need to set the chart to be a Continuous Futures Contract chart: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
