Date/Time: Sun, 16 Mar 2025 23:55:18 +0000
Delta % display
View Count: 511
[2022-08-22 17:59:16]
Reghard14 - Posts: 3
Hi SC,
I am looking for a setting to display the Delta % on the footprint as an actual %. Mine is showing a clear % but one of my traders cant get his platform to show it as a %. The platform shows it as a normal number so for example 1% will be displayed as 0.01.
I have attached a screenshot with the area in question marked. He is using my footprint so the settings are the exact same.
Thanks in advance.
imagemmexport1661185911619.png / V - Attached On 2022-08-22 17:57:59 UTC - Size: 621.88 KB - 240 views
[2022-08-26 11:16:26]
Sierra_Chart Engineering - Posts: 18800
This is controlled through the Display Percent Values as Decimal or Percentage Input:
Chart Studies: Adding/Modifying Chart Studies
