Date/Time: Sun, 16 Mar 2025 16:24:11 +0000
regain vertical space when region title is blank
View Count: 382
[2022-08-22 17:28:58]
JohnR - User831573 - Posts: 320
I have turned off options & removed what I think are all possible things that would appear on a region / subGraph in an attempt to get that space back to be include in my study vertical scale usage. Please direct me to the steps or info I need to be able to regain this space. In my charts that would be approx 20% of the space within that region, which is a lot to lose.
Thanks for your time to reply,
JohnR
imageRegain space from region title line2022-08-22_13-18-52.jpg / V - Attached On 2022-08-22 17:27:33 UTC - Size: 110.21 KB - 119 views
[2022-08-22 18:22:04]
User431178 - Posts: 614
Chart Settings: Regions
Working With Charts: Chart Window and Regions
Chart Scale and Scale Adjusting: Scale Padding Percentage (Scale Settings)
Set the region to hidden and reduce the scale padding percentage.
[2022-08-22 19:19:58]
Thanks for the links. I have looked at that new Chart - Region menu and never clicked to see what the options were. I knew it had to be possible, as most everything is possible within SC.
Again - Thanks
JohnR
