Date/Time: Sun, 16 Mar 2025 15:12:37 +0000
Can't change Candlestick-Colors after I changed Data Feed / Verticalline at session start?
View Count: 385
[2022-08-22 13:17:42]
User278435 - Posts: 12
1) after I changed my Data Feed from CQG to Denali, I can't change my candlestick colors?
( want up Candlestick in white and down candlestick in black)
I did: Chart - graphic/settings - unchecked Use Global Graphics settings -
Bar High-Low Down Black and Bar High-Low Up White, it didn't work)
2) Is it possible to draw a vertical-Line at session start, like in the old chart settings menu?
If so How?
Thank you!
Kevin.
[2022-08-22 14:06:11]
Sierra_Chart Engineering - Posts: 18797
1. Should be no trouble with this at all. This has no dependency at all upon the connected Trading service. Check the settings again. Make sure there are no studies (Analysis >> Studies) on the chart to ensure that there is not a particular study which is replacing the candlestick bars or overlaying them.
2. Refer to:
Chart Menu: Vertical Grid (Chart menu)
Date Time Of Last Edit: 2022-08-22 14:06:25
