Date/Time: Thu, 19 Sep 2024 21:52:26 +0000
Rithmic Logon Issue
View Count: 1036
[2014-05-13 11:44:10] |
xfighter - Posts: 36 |
I just update to version 1136. Then when I try to connect my trading account, I got actively refused by Rithmic server machine. I noticed the port is 80 now while in previous versions, the port is random (something like 38994). I then rolled back to v1135 and everything works fine. Here are the messages: Rithmic Trading - Port for executable: 0 | 2014-05-13 07:42:17 Rithmic Trading - Starting server: C:\SierraChart3\Rim\DTCBridge.exe | 2014-05-13 07:42:17 Rithmic Trading: Connecting to the server 127.0.0.1. Port 80 | 2014-05-13 07:42:20 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-05-13 07:42:21 Socket has been shutdown and closed. | 2014-05-13 07:42:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-05-13 07:42:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-05-13 07:42:21 Rithmic Trading: Disconnected from the server. | 2014-05-13 07:42:21 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-05-13 07:42:21 Rithmic Trading: Bridge process is still running. | 2014-05-13 07:42:23 Rithmic Trading: Connecting to the server 127.0.0.1. Port 80 | 2014-05-13 07:42:25 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-05-13 07:42:26 Socket has been shutdown and closed. | 2014-05-13 07:42:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-05-13 07:42:26 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-05-13 07:42:26 Rithmic Trading: Disconnected from the server. | 2014-05-13 07:42:26 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-05-13 07:42:26 File >> Disconnect selected. | 2014-05-13 07:42:26 Rithmic Trading: Disconnected from the server. | 2014-05-13 07:42:26 |
[2014-05-13 16:16:47] |
We will fix this. We will have a new release out in about two hours.
