Date/Time: Sun, 16 Mar 2025 12:28:17 +0000
Is possible to change format of time scale display for cursor value?
View Count: 511
[2022-08-22 09:34:24]
donnicky - Posts: 33
For example, in the attached screenshot it would be enough to just show year value.
image2022-08-22_12-31-27_8dafaa07-af89-4e26-9be3-e1763d3ac07f.png / V - Attached On 2022-08-22 09:33:31 UTC - Size: 42.38 KB - 112 views
[2022-08-22 11:16:04]
Sierra_Chart Engineering - Posts: 18797
Is this historical daily bar data? Not Intraday data?
[2022-08-22 11:34:58]
This is historical chart with yearly bar period.
image2022-08-22_14-33-53_10e07433-f767-4a7c-a94c-57f03850be24.png / V - Attached On 2022-08-22 11:34:40 UTC - Size: 46.29 KB - 104 views
[2022-08-23 18:50:18]
If you update to the latest prerelease there are new settings in Global Settings >> Tool Settings >> Chart Values to control this.
