Date/Time: Mon, 17 Mar 2025 07:07:46 +0000
Trading dom
View Count: 563
[2022-08-22 05:53:41] |
User562957 - Posts: 58 |
Hello everyone, I didnt trade a long time and in the past the trading dom can manually with the mouse get thicker and wider the fields in the dom. But now I cant to that. How can I change the fields in the dom to make it bigger ? |
[2022-08-22 08:47:11] |
Sierra_Chart Engineering - Posts: 18801 |
Refer to: Global Trade Settings Windows: Chart/Trade DOM Column Widths and Headers (Trade >> Customize Chart/Trade DOM Columns) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
