Date/Time: Mon, 17 Mar 2025 23:59:28 +0000
ZigZag affected by another indicator
View Count: 453
[2022-08-21 22:19:18] |
mwnl - Posts: 29 |
Hi, I have the zigzag indicator on my chart. When I enable the high-low for time period study it throws all of the zigzag lines away from price. Please can you help me fix this? I've attached screenshots showing the zigzag with and without the other study enabled. |
![]() ![]() Attachment Deleted. |
[2022-08-22 03:41:31] |
Sierra_Chart Engineering - Posts: 18812 |
Make sure the Scale Range for the ZigZag study and the main price graph are all set to "Automatic": Chart Scale and Scale Adjusting: Maintaining Same Scale for Multiple Graphs in Chart Region Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
