Date/Time: Thu, 19 Sep 2024 22:03:19 +0000
Colour an area on the chart
View Count: 1036
[2014-05-13 10:25:52] |
User54027 - Posts: 128 |
Hello Support Please could you let me know if it is possible to colour an area on the chart without drawing lines. For example if I wanted to colour the area between the values 15000 and 15100 light blue, is this possible? Thanks. |
[2014-05-13 17:21:37] |
Yes. This can be done with the Horizontal Lines study. Refer to this section here: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#FillingArea Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
