Date/Time: Sun, 16 Mar 2025 15:10:18 +0000
Hi I attached a screenshot of the problem I'm having with Sierra Charts.
View Count: 523
[2022-08-20 21:57:29]
User893516 - Posts: 13
When i go to open any of the tools up top of the tool bar. the screen opens up with a black box...its very confusing.
i want to goback or get back the normal settings not this black screen somebody please help thanks!!
imageScreenshot (6).png / V - Attached On 2022-08-20 21:54:35 UTC - Size: 282.35 KB - 119 views
[2022-08-21 07:35:04]
Sierra_Chart Engineering - Posts: 18797
Refer to the information here:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#NewChartSettingsWindow
[2022-08-22 06:49:33]
Thank you, Can you send the link, where it shows how to change the dom settings. I want to chnage the profit and loss to dollar vaule not points.
[2022-08-22 06:50:22]
change Dom to show the P&L in dollar value, not points
[2022-08-22 08:44:27]
This is done through Chart >> Chart Settings >>Trading >> Profit/Loss Format. Refer to:
Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu)
