Date/Time: Thu, 19 Sep 2024 22:09:33 +0000
window detached and hidden menu
View Count: 1503
[2014-05-13 08:45:14] |
AKR - Posts: 523 |
is there any way to get back the menue once a chart is detached and the menue hidden? or a way to restore the window size once it was maximized? |
[2014-05-13 09:14:14] |
On the main Sierra Chart window select Global Settings >> Customize Chart Shortcut Menu. Add the "Show Menu" command. You can then right-click on the detached chart and select that command. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-13 09:18:35
[2014-05-13 09:19:00] |
Actually, if you have a look at the Chart Menu documentation page and go to the Show Menu section, all of this is explained there and some additional details. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
