Date/Time: Sun, 16 Mar 2025 12:39:29 +0000
Chart toolbar with
View Count: 537
[2022-08-19 20:54:41] |
User525965 - Posts: 153 |
One of my charts in my chartbook does not have the same title bar as the other charts. I'm struggling to get it on the chart. I went to chart > show title bar, but nothing comes up. Here is an example of what I want it to look like.
[2022-08-20 14:43:04] |
Sierra_Chart Engineering - Posts: 18797 |
Is this chart you are referring to, not the one in the picture, a Detached chart? For more information about that, refer to: Detaching and Attaching Chart Windows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-20 14:43:25
[2022-08-21 17:10:29] |
Yes its a detached chart. But even when I attach it, the title bar does not show.
[2022-08-22 05:43:12] |
A detached chart is not going to have a title bar like the main window. You can put a Control Bar on it through Window >> Control Bars.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-22 05:43:19
