Date/Time: Thu, 19 Sep 2024 22:04:45 +0000
Request: change Associated Watch List Window Size
View Count: 1027
[2014-05-13 08:21:48] |
4646ed - Posts: 230 |
Any way you could make the Associated Watch List Window smaller? It takes up a third of my notebook monitor, and with a couple open on the large monitors it gets in the way alot. Maybe make it so all the options on the left are menu items, and make the instruments a drop-down list? Or even better, turn it into a button that's attached to each chart, that you can open/close as you wish. Date Time Of Last Edit: 2014-05-13 08:30:23
[2014-05-14 05:01:33] |
This will be considered later on. Probably more towards the end of the year.
[2014-05-14 08:01:16] |
thanks for the prompt reply
