Date/Time: Sun, 16 Mar 2025 15:12:38 +0000
Initial Balance Study and Backing up Sierra Platform
View Count: 395
[2022-08-19 18:28:42] |
Steve Leon - Posts: 312 |
1) I am using the Initial Balance study to achieve the goal i want. I am having it label the initial balance high/low for the day/cash session. I would like to have the labels be removed at the end of the session. There does not seem to be a way to do this using this study ? Should i use a different study ? What study is best for removing labels that are time sensitive from one session to the next ? 2) I was told by a computer technician that i should consider backup my Sierra platform onto my external drive every once in a while ? Any thoughts or suggestions on this ? How should i do this ? Is there a feature on Sierra that will export this to the external drive ? or should i copy the Sierra folder and paste it in the external drive ? How best to do this ? Thank you |
[2022-08-22 16:35:35] |
Sierra_Chart Engineering - Posts: 18797 |
1. This is not supported but you can modify the study to meet your requirements: How to Build an Advanced Custom Study from Source Code However, as time passes by if you want it to follow the Number of Days to Calculate study Input, then you need to reload the chart with Chart >> Reload and Recalculate. 2. Refer to: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-22 16:36:05
