Date/Time: Mon, 17 Mar 2025 04:27:17 +0000
Market depth quantity
View Count: 437
[2022-08-19 14:24:20] |
User155457 - Posts: 14 |
Hello, this has randomly stopped working, i have gone into global settings-symbol settings then go to the symbol and set the minimum MBO quantity, its works for the first 10mins and then shows all again, I disconnect from server then reconnect and it shows the correct quantity and then 10mins later its showing all again, please advise. Thanks |
[2022-08-19 17:55:28] |
Sierra_Chart Engineering - Posts: 18801 |
Could you update Sierra Chart to the current version: Software Download: Fast Update See if that resolves the issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
