Date/Time: Sun, 16 Mar 2025 16:19:27 +0000
easy ways to disable alert
View Count: 769
[2022-08-19 02:16:20] |
User970210 - Posts: 100 |
Hi, are there any easy ways to turn alert sound on and off from chart studies altogether? thx Song |
[2022-08-19 14:33:00] |
Ackin - Posts: 1865 |
Mute All Alert Sounds (Global Settings menu) Global Settings Menu: Mute All Alert Sounds (Global Settings menu) |
[2022-08-19 15:10:48] |
I have multiple charts opened for trading. I just would like to disable alert sound from those charts not in focused. mute all wouldn't do it for me.
[2022-08-19 16:05:13] |
Sierra_Chart Engineering - Posts: 18797 |
You have to do this manually using these Edit menu commands: Edit Menu: Edit >> Disable All Alerts - Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-19 16:05:20
