Date/Time: Sun, 16 Mar 2025 13:48:15 +0000
Trial version not working
View Count: 427
[2022-08-19 01:25:32] |
spelmansiya@gmail.com - Posts: 1 |
Good day, I downloaded the software, but the 14-day trial is not working(it says it has expired within a few hours on installation) - as a result, there is no data feed to look at. May you please assist me with this matter? I would like to get a feel of the software before making possibly making the purchase. Regards, Siyabonga spelmansiya@gmail.com Date Time Of Last Edit: 2022-08-19 01:26:33
[2022-08-19 06:55:40] |
Sierra_Chart Engineering - Posts: 18797 |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
