Date/Time: Tue, 26 Nov 2024 14:29:43 +0000
[User Discussion] - Lead time for sound alert
View Count: 1395
[2014-05-13 07:14:18]
User93734 - Posts: 2
hi
I wish to use the sound alert before closing the bar for a few seconds, it can be done?
thanks
[2014-05-13 07:29:50]
So you want a sound a few seconds before a bar closes?
[2014-05-13 13:19:43]
yes
[2014-05-13 17:15:50]
This would require custom programming. You could use the Countdown Timer as a reference. Refer to the documentation here to get started with this:
http://www.sierrachart.com/index.php?l=doc/doc_BuildCustomStudiesDLL.html
Date Time Of Last Edit: 2014-05-13 17:16:02
[2014-05-13 17:19:39]
Sawtooth - Posts: 4120
Here is a spreadsheet study that does this:
http://www.sawtoothtrade.com/free-stuff-11.html
Date Time Of Last Edit: 2015-08-14 02:00:15
