Date/Time: Wed, 15 Jan 2025 02:51:07 +0000
intraday chart does not display any data
View Count: 643
[2022-08-18 21:39:39]
bluesky_trader - Posts: 4
Hi Team,
I am new user, just joined sierra charts and I use it mainly for charting.
The issue I am facing is that I am not able to load Intraday charts like 1 min, 5 min etc for NASDAQ stocks. After the message that historical data load is complete nothing comes up for intraday, it's just a blank screen that I get. If i switch to 1 day then I could see data.
I read some of the help document and followed steps like updating the symbol settings etc. I am selecting the symbol ending with NQTV like APPL.NQTV etc
The same works fine for futures and I am able to see data for ES, NQ.
FYI I have subscribed to NASDAQ market data.
So I need support team to help me on this.
Date Time Of Last Edit: 2022-08-19 09:01:42
[2022-08-19 14:21:10]
Sierra_Chart Engineering - Posts: 17947
Make sure you are using the correct symbols. You can find them in File >> Find Symbol >>NASDAQ TotalView.
That is not a correct symbol that you gave above.
Refer to:
Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes
[2022-08-19 16:06:25]
sorry it was a typo error I did select the correct symbol which is AAPL-NQTV
I am attaching few images for reference of the issue I am facing.
https://www.sierrachart.com/image.php?Image=1660924886706.png
https://www.sierrachart.com/image.php?Image=1660924938736.png
daily chartis working as expected, only intraday is blank
https://www.sierrachart.com/image.php?Image=166092509226.png
Private File
[2022-08-19 16:41:04]
The issue must be related to the Session times:
Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart: 3.3 - Session Start Time and End Time not Covering Current Time
Set the time zone of the chart to US Eastern Time:
Time Zone Setting: Using Different Time Zone in Individual Charts
Apply the session times to the chart:
Chart Session Times: Automatically Setting Session Times
[2022-08-22 16:05:32]
Thanks it fixed the issue
