Date/Time: Sun, 16 Mar 2025 16:24:11 +0000
Link zero level of LH scale to zero level of RH scale
View Count: 449
[2022-08-18 19:01:39]
503 - Posts: 10
As in the description, is there anyway to synchronize zero level of both scales (left or right) so that no matter how the range is changed on each side, the zero levels will remain in the same place relative to each other.
[2022-08-18 19:05:26]
John - SC Support - Posts: 38678
There is not a way to do this.
[2022-08-18 19:37:30]
Sierra_Chart Engineering - Posts: 18797
If the graphs setting the scales in that Chart Region are set to an Automatic Scale Range, this will be the case.
Date Time Of Last Edit: 2022-08-18 19:37:46
