Date/Time: Sun, 16 Mar 2025 16:19:28 +0000
LARGE VOLUME TRADES
View Count: 670
[2022-08-18 18:13:45]
User411320 - Posts: 303
the large volume trade study is not showing anything on my NQ chart
[2022-08-18 18:46:07]
John - SC Support - Posts: 38678
What are the following Inputs for the Large Volume Trade Indicator set to:
- Volume Threshold
- Draw Mode
- Marker Style
- Draw Volume Text
[2022-08-18 19:44:17]
- Volume Threshold- 25 (I've also tried as low as 2)
- Draw Mode- BASED ON TOTAL VOLUME ABOVE THRESHOLD
- Marker Style- CIRCLE
- Draw Volume Text - TRANSPARENT
[2022-08-18 20:43:21]
Do you have anything entered for the Do Not Display Values Less Than input?
Or are there any other Inputs that are set different from the default - such as the Text or Marker size, or the Percentage Above/Below Median for Maximum/Minimum Volume in Chart?
If all of these look good, then we would need to get a copy of your chart by following these instructions:
[2022-08-19 10:52:30]
Do Not Display Values Less Than = 0
attachmentLVTHelp.Cht - Attached On 2022-08-19 10:51:59 UTC - Size: 3.34 KB - 296 views
[2022-08-19 14:12:26]
Sierra_Chart Engineering - Posts: 18797
This is what we see using that Chartbook:
https://www.sierrachart.com/image.php?Image=166091831411.png
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here:
The numbers and circles are from the Large Volume Trade Indicator study.
Date Time Of Last Edit: 2022-08-19 14:12:48
[2022-08-19 15:00:51]
that worked thanks
[2022-08-19 15:06:20]
before you go ,
the bid dominant color is trades hitting the bid or lifting the offer? same question for the ask dominant color
Also, how can I set up so that I only see the maximum?
thanks
[2022-08-22 21:02:56]
The Bid dominant color would be for Trades and the Bid. The opposite for Ask dominant color.
This is supported. This is the Draw Mode you will want to use:
Based on Total Bid or Ask Volume Above Threshold
Date Time Of Last Edit: 2022-08-22 21:03:17
