Date/Time: Sun, 16 Mar 2025 21:26:20 +0000
prior week high prior week low
View Count: 722
[2022-08-18 13:37:18] |
User707307 - Posts: 84 |
Hello, I am trying to create a label that tells me where the prior week high and prior week low is located. How can I do this? Thank you |
[2022-08-18 16:01:41] |
John - SC Support - Posts: 38678 |
Refer to the information we provided in this thread: Overnight VPOC For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-19 18:26:42] |
I don't understand a way to do this, I asked for something completely different than the ONVPOC. I want to track the prior weekly low and the prior weekly high. So I need a study I can select to X bars back. There's no way to do this with the study overlay. I aslo tried using the overlay of OHLC but there is no way to do that. Can you help me a little mroe please? Thank you for your time again, John |
[2022-08-19 18:42:20] |
I also used period OHLC- Variable Period, and I can set up weekly high and low. But there's no way with this indicator I can show the labels of the PRIOR week instead of THIS week. |
[2022-08-20 10:32:54] |
Ok I was finally able to do so. I did that on a different way but thank you anyway
[2022-08-24 11:22:16] |
Sierra_Chart Engineering - Posts: 18799 |
Here are the relevant studies for this: Previous/Period OHLC-Variable Period Text Display For Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
