Date/Time: Sun, 16 Mar 2025 12:36:57 +0000
Overnight VPOC
View Count: 699
[2022-08-18 13:32:58]
User707307 - Posts: 84
I am trying to create on my RTH chart, an ONVPOC label.
Is there anyway I can do this?
Thank you once again
[2022-08-18 16:00:40]
John - SC Support - Posts: 38678
If you are wanting to see the Overnight POC on the daily bars (or even just get the label from the overnight) then you would need to setup a second chart that is just the overnight hours and put the Volume Value Area Lines on that chart and set it up how you want to get the POC for the overnight session. Refer to the following for the Volume Value Area Lines:
Then use the Study/Price Overlay on the RTH chart and set the Input for Match Source Bars to Destination Bars to No. Refer to the following for the Study/Price Overlay:
Study/Price Overlay Study
Then if you want the Value Label just in the RTH chart, you would need to change the Input for the Study/Price Overlay for Use Subgraph Name/Value Related Display Settings from Source Study to No, then you can turn on the Value Label in the RTH chart. Refer to the following for the labels:
Chart Studies: Subgraphs Tab >> Name and Value Labels
[2022-08-19 23:02:35]
Something strange happens. I have set that up the same that for the 200SMAs. And for the 200SMA's I was able to track them like I want on a daily chart. But not for the ONVPOC.
Attached you have the setting but the ONVPOC is on 4230.75 instead of 4287s
How is this possible?
Can you help me please?
Thank you John
imageonvpoc.png / V - Attached On 2022-08-19 23:00:51 UTC - Size: 134.21 KB - 120 views
[2022-08-20 11:04:45]
I was now able to do that by using two separate volume profiles. One for the ON session another for the RTH. Then using the Overnight poc to chart on the RTH. Thank you.
